When reinstalling the drive, whats the easiest way to line up the spline? Put the drive in gear and rotate, or do you have room to turn it at the u-joint still with the drive in neutral?<br /><br />If in gear, do you put the shift lever in gear to line up on the shift rod, or reach in with a screwdriver etc., and put the shift rod back in neutral before sliding the drive all the way in?<br /><br />Thanks
