TRobin9496
- Jun 6, 2010
- 9
I converted my Cobra outdrive to an SEI-116 yesterday using their conversion kit. I was looking for someone who had already done this to see if they had any issues with the height of the drive after the conversion. After doing the conversion, with the trim cylinders fully extended, it looks like the bottom of the outdrive is about 6" lower than old Cobra outdrive. The bottom of the Skeg is about 6" off the ground when the trailer is connected to my truck. It's so low that I'm worried about dragging the skeg when the truck suspension flexes over bumps in the road.
Has anyone else had this problem after doing the SEI Cobra conversion?
I'm trying to figure out a way to extend the trim cylinder length to allow the drive to be raised higher. When the drive is fully down(both the old one and the SEI), there's still about 3-4" of the trim cylinder ram showing, so I could extend the cylinders by about that much and still be able to lower the outdrive fully.
I know another option is to buy Alpha 1 trim cylinders, but at $400 each, that's not an option I like.
Just thought that if SEI's cobra conversion makes the drive hang that much lower in full tilt up, this should have been mentioned on their web site or in the literature.
