Cobra 1990 - Oil from Trim pump
dodge1930
Hi,
OMC 1990 3.0L Cobra, (302BMRPWS)
Need to add Fluid to the trim pump, one place they say use Power Steering Fluid,
another place say to use Transmission Fluid.
Thanks Steve
Jono69
Re: Cobra 1990 - Oil from Trim pump
A lot of stores carry marine outdrive specific fluid for your trim pump. Wally Word, Farm and Fleet, etc all have them. I would go with one of those personally. If in a pinch, transmission fluid would work.
dodge1930
Thanks,
Why I was asking is the previous owner said he used Power steering Fluid.
Should I drain it out ans replace it??
HT32BSX115
Thanks,
That system is probably one of the simplest hydraulic pump/actuator systems there is.
About ANY petroleum based light oil will work.
Just put in whatever the previous owner said he used.
Ayuh,.... Ditto that,...
