Re: Cobia Fishing Help?
The cobia bite doesn't come on for a little while yet. They like the water a little warmer than it is right now. <br /><br />As far as tackle and bait, you will need a good strong rod and 20-40lb test. There are several ways to fish for them, but most folks use a fish finder rig and a good size hook with cut bunker, live spot, or live eels.<br /><br />In late May or early June cobia begin coming in the bay from the south in droves, they like to hang around structures, so you can try casting a tube eel or live spot around the buoys from Rudee inlet north through the CB line.<br /><br />Also, folks anchor up on Lattimer Shoals and fish with the fish finder rigs while chumming and using menhaden oil to make a slick. <br /><br />Any way you do it, don't get discouraged if you don't get on them your first few times. Cobia fishing is like anything else, keep trying at it long enough, and eventually you get it right!
