Huron Angler
- Apr 7, 2009
- 6,025
I am in the process of getting my rig ready as my restoration is progressing and I'm having an issue with my CMC hydraulic tilt/trim bracket.
The manual states as first troubleshooting step:
"Try re-setting the circuit breaker. The circuit breaker is located on the red wire coming off the positive battery post. Press in the small tab located on the side. The circuit breaker is now reset."
I can't find the circuit breaker so I didn't get far.:redface:
The black box to the right of the battery holds two 30 amp relays. I have already tried swapping them.
The bilge pump works, and is the only other thing hooked up besides the 80hp Merc.
The black box holding the relays "clicks" when I try to move the bracket up or down, so the wiring seems correct.
My question is where is the circuit breaker so I can reset it?
Thanks for any assistance
