CMC Jackplate elecrical issue
RGKSTV
When i try to trim my jackplate up all i hear is the relay clicking but the plate doesnt move, could it be the relay or is it more likely an other issue? Just looking for a starting point. Thanks
First, check all the battery connections. Clean as required.
If that doeant work, take a screwdriver and jump the relay. If the motor moves, its the relay. If the motor doesnt move, look at the motor
RGKSTV
Thanks! Ill start there, I also found CMC manual which will help as well.
