Clutch slipping/gear
The Pogue
I own 89 Mercury 25 hp the other day opened throttle wide open to see what she would do and it started going almost wide open and then it sounded like a trucks clutch slipped and rev d up loud so I eased back on throttle and it caught the gear! Any help would greatly appreciated! Just so u know, I don’t have an arm/leg to pay for repairs if I can fix myself!
Chris1956
Outboards do not have clutches in the traditional sense. They are either in gear or out of gear.
Props have rubber drive hubs that can slip. Take the prop to a prop shop and see if it needs to be rehubbed.
jimmbo
Possibly the prop caught some air and lost its bite, when you lowered the rpms it grabbed the water again.
It is much easier to look at the pic when it is oriented correctly
Click image for larger version  Name:	zxzxsx.jpg Views:	1 Size:	28.4 KB ID:	10869244
Looking at the picture, it appears that the motor might be too long for the Transom, but that might just a Perspective Distortion
The Pogue
It’s definitely a long shaft the transom is only 15”?
Just bought the boat few months ago!
harringtondav
Same as above. Dog clutches are either engaged or not. Trash/weeds on you prop will cause it to break loose/cavitate. If you prop's hub slipped under power it will do it again.
Texasmark
Get a marker and mark from the center of the prop...where metal meets metal of the prop shaft, straight out to the outside of the prop hub. Run it and get it to act up. Examine your mark. If intact a fluke of your operation or entangled weeds. If no longer intact, a slipping hub.
Rubber, pressed in hubs are designed to take a strike, lose friction connection with the prop barrel, allowing the prop to only deliver part of the drive applied to it and upon doing what you did (cut the throttle), reseat to a solid connection and function properly. If it is caused to slip too often you can damage the surface between the hub and barrel and it will will slip frequently forcing replacement of the hub (new hub pressed in), usually by a prop shop. For the cost of a new prop for that engine I wouldn't bother with a prop shop, just go to the top of this page and under props, order you a new one.
On a 20" midsection on a boat designed for a 15", you have plenty of water at your disposal, just a lot of lower unit drag which reduces your top speed and makes for reduced shallow water operation. Sooooo, unless you picked up some weeds around the prop, I don't see how you could cause prop blowout with your operation of the boat and slowing down wouldn't clear weeds. Were the situation reversed (lengths opposite) then it would be a problem at all speeds but idle.
If the length is a problem for you, considering your boat, just raise the engine mounting portion of your transom 5". 25 hp isn't all that much and wouldn't require a lot of effort.
