jcorrigan
- Feb 13, 2010
- 21
So as stated in another thread, I took the boat out this weekend for it's second journey and discovered while giving her a bit more gas than the last excursion (getting gutsy) that above certain speed the boat stops moving forward but the enging revs higher!
Searching through the posts (http://forums.iboats.com/showthread.php?t=104790) revealed that this may be the Clutch Dog? With the motor being a 64 Evinrude Speeditwin (again, gleaned from the posts here) I don't doubt that some of the parts are starting to show their age.
My question is am I on the right track? Should I check the shear pin first? Will the prop turn at all if the shear pin is gone?
Guess I should add "As a first time boat owner am I WAY outta my league here and should just take the boat to a marine mechanic?
