My motor is evinrude, 4 hp, 1976 year. It runs so hot it shuts down by itself. I put in new wear plate, impeller, but still runs hot. I put lower unit in bucket of water on a drill press table. I put the drive shaft in the chuck, and at the slowest speed of the drill press, the water shot up about a foot and was the diameter of the rubber bushing. So I am getting a lot of water to that point.<br /><br />I attached a flexible hose to the pipe that carries the water to the power head and blew on it. It is not blocked, but I had to blow pretty hard to get the air thru.<br /><br />What can I introduce into the narrowed power head passages (via the long pipe) that will eat away at the build up on the water passages in the power head, that will not eat thru the aluminum and into the cylinders? thanks
