Thanks in advance for any advise you can give. Last weekend my speedometer stopped working, right after having the upper half of the Alpha outdrive replaced. Thought it might be the pitot tube came loose, but not that lucky. Discovered today that the speedo water inlet hole is clogged. Thought it was just some of our famous Georgia clay, but nope, it appears to be some wood that has become lodged in there. Tried picking it out today, but only able to clear about 1/4 inch. I checked another drive on a boat next to mine and found that the hole goes into the drive housing about 2 inches or more before turning upward. I'm thinking that to remove this wood that I will need to VERY carefully and very slowly use a 1/32 or 1/16 inch drill bit and drill the wood out. Perhaps disconnect the pitot tube from the top of the drive unit and blow air from the top to push out any small pieces left behind. Any thoughts or ideas on how better to go at this? Man, what are the chances of something like this happening!
