Clinton K500 1975 Need help
martinc2
I just got this Sea King and it appears to be in relatively good shape. It has a spark and compression. The plug is the right color. I don't have the fuel connector (female)so can't get fuel to it to try it out. Where can I get one? Also, I don't see anyplace to put gear oil into the lower end? Is there anything I should know about this motor? I'm assuming it uses the older 1/16 or 1/20 fuel ratio. Is there a manual on line somewhere?(Vancouver, WA)
