clicking noise when spinning prop
jeffw0038
When i spin the prop on my OMC cobra i'm hearing what seems to be a clicking noise, would this be a shifting cable out of adjustment?
dobler5
Re: clicking noise when spinning prop
Yes, I had the same problem. You gear is not fully locked into gear. It is either stuck between neutral and forward or neutral and reverse. Its not all the way shifted into gear.
bruceb58
Is it doing this while in neutral or in gear?
If in gear, it will click in one direction but not move in the other. For example, in forward, should not move if spun counterclockwise.
jeffw0038
It does it when in neutral. So does that mean when i start it it will be in gear and won't want to start because of that or is it really in neutral? I have to buy a batt for it when i get back home so can't give anymore info now. I brought it home last weekend and noticed the problem.
Thanks
Jeff
Friscoboater
Mine is not an OMC, but my merc did that when the shift cable was out of adjustment. No the reason mine was out is because I pulled the engine and messed up the adjuster. If yours is just started doing this, it might be stretched. I would wait for the gurus to confirm this.
bruceb58
Sounds like out of adjustment.
jeffw0038
Hope that is all, not wanting to put a new cable in unless i have too;)
jburn25
Mine also clicks when i spin it in neutral. I think there may in fact be some slack in my steering cable...only problems it that the props clicks when i take the lower unit off and spin it.
should it click even when lower unit is disconnected?
