Re: Clicking noise from forward into reverse?
The dreaded L-drive, or should I say hell drive. It sounds like you need to adjust the shift yoke on top of the out-drive. You'll see where the shift cable meets the drive right next to the exhaust bellow. You'll need to pull the cotterpin and then the pivot pin, then the arm that holds the shift cable will lift off. Trimming the motor fully up first will make this easier. It sounds like you need to turn the yoke, that the cable arm was connected to on the drive, out(un-screw). Go 1 turn at a time until you get close to where you want to be then take it in half turns. It doesn't sound like you need to adjust it much. I have a '91 l-drive on a 120hp that I did alot of work to last spring. Should be pretty close to the same. Hope this helps.
