Joachim_Halse
- Aug 5, 2016
- 2
Hi folks,
my mercruiser alpha one 3.0 ltr mounted in a 1984 Wellcraft 180 bowrider is making a loud clicking sound when I put it to hard work, for example pulling the tube with two-three people on it out of the water, or pulling two small wakeboarders until the boat is on plane. As soon as the boat is on plane, the clicking stops. Or if I pull back a bit on the throttle and allow for a longer time to get out of the water the clicking also stops. When idling or cruising at a fixed speed there is no clicking. In other words, the engine clicking is related to aggressive acceleration at full throttle and seems to get worse with higher water resistance from towing. My question is, what can be causing this sound? I am not sure about the source location beyond somewhere in the engine compartment, since I dont like the idea of running full throttle and people on tube, while the whole backseat is flipped open... Am I over-burdening the engine or drive?
Thanks
Thanks
