Re: Cleaning carbon off pistons?
Try products such as Carbon Guard, OMC Engine Tuner or NAPA Seafoam. Do a complete decarb- you can find<br /> this procedure in this forum- go to search and type in. You may want to also add these products to your gas tank on an alternate basis as protective maintenance.Some guys use synthetic oils on their 2 strokes because they burn cleaner with far less carbon. As far as head gasket- make sure there is no warping of the head itself- and from experience (my engine- yours may require something totally different) NO sealant should be used. Make sure to torque the bolts with the correct pressure. Re-torque after 10 hours of use.
