Cleaning Camper Canvas Plastic Windows
Status
Not open for further replies.
mrom1234567
Re: Cleaning Camper Canvas Plastic Windows
Pledge works really good.<br />It sounds strange, but try it.<br />Clean them with soap and water first.<br />Michael
Terry H
If you clean those windows too well the wapiti will be able to see in...just a thought :)
Stratocaster
Meguiar's make some very good plastic cleaners and polishes. I use a product called "Klear-To-Sea". It meets a bunch of military specs for aircraft plexiglass and works great.<br /><br />If your windows have gone cloudy, however...don't waste your time or your money. They're done. Get them replaced at a canvas shop, it's not terribly expensive.<br /><br />Mike P
hise
Yup, Pledge is the ticket.<br /><br />--Hise
Scaaty
Curious if anyone has tried Armor All or similar?
starrider_68
I tried that armour all...made the plastic soo soft they HAD to be replaced...seems like they wanted to "run" down and sag after that.
Boatin Bob
Our canvas guy also recommends "Pledge" but he says NOT to use the lemon kind because the citrus acid in it actually removes oils from the plastic and shortens the life!
lakelivin
I saw some tips about cleaning the plastic windows on a Miata convertable when a girlfriend had one years ago. Don't remember where, but do remember they had some solutions people said worked fairly well. Might be worth doing a google search on "Miata plastic windows cleaning".
Bob_VT
Novus Plastic polish works great. <br /><br />Bob
lakelivin
Found the info on the Miata, would think it should work similarly on RV plastic.<br /><br />Keeping Your Miata Plastic Rear Window New - Left unattended, a plastic Miata rear window will become yellow, then cloudy brown, and finally will crack. Don't let this happen to you. Purchase a bottle of Meguiar's #10 or Novus #2 plastic polish, and a bottle of Meguiar's #17 or Novus #1 plastic cleaner. Apply the polish liberally to the rear window with a cotton ball. Rub it out. Then clean the window with cotton and the cleaner. Finally, polish with a clean terry towel. This process will remove scratches, and will restore plasticizers necessary to keep your window flexible and clear. A plastic rear window should remain clear and soft even after ten years if properly cared for.
Status
