I purchased a 20ft pontoon boat that had been sitting in the water for a little over 3 years.
The tubes were absolutely ugly with stains etc from sitting in the water for so long. I have the tubes looking pretty good but have been unable to figure a way to raise the boat high enough to clean the very botton of the tubes. A friend of mine sugested renting 2 engine hoists and raising the boat by the two eyes welded to the back of the tubes/
Are these eyes strong enough to raise the boat with the engine attached (40hp Johnson)???? After the boat has been lifted off the trailer I plan to place either 4X4s or old tires under the tubes and then lower the boat back onto the trailer. Will this damage the bottom of the tubes??
Second Question: If this is a workable solution to raising the back of the boat, how do we raise the front? Would straps under the logs using the engine hoists work???
Thanks
Thanks
