mgmidget72
- Sep 30, 2009
- 99
So I've finally traced the problems (see thread here) that I was having with my new (to me) boat to there being something wrong with what was coming out of the gas tank (built-in). Not sure if it's water, old gas, or something else, but I'm draining the tank. If it matters to give an answer to my questions below, I'd have to guess that it was water based on what I saw coming out.
Will simply pumping it empty from the fuel pick-up (on mine, it's a rigid hose going down to the bottom of the tank with a metal screen filter on the end) be enough? Or should I tilt the boat and put a tube down into a corner of the tank? Or do I have to go farther and clean it somehow?
Thanks,
Scott
Thanks,
Scott
