Cleaning aluminum windshield frame
jim burford
How can I clean my windshield frame, I have tried several cleaners, for pontoon boats, but I still have dark tarnish in spots all over my windsield frame?
dompie99
Re: Cleaning aluminum windshield frame
ok<br /><br />I.m no espert BUT, a LIGHT buffer with a THICK pad with very fine ( grit 1000 or 2000) would be more than adequate to revive your Alu frame.<<br /><br /><br />When you gata go, use Hydrostream, or DIE.
crazy charlie
Try some Flitz or Noxon and a green scrubbie pad.This is assuming the frame is not on a new boat.Charlie
jim burford
It is a 1985 Sea Ray 255 Amberjack,the boat looks good but the windshield looks bad. Where can I find Flitz or Noxon.
crazy charlie
Just try the scotchbrite pad first with some water.See how that works and finish it off with some brake fluid.Wear gloves because your fingers will turn black right away.Flitz is a marine store item and noxon or even barkeepers friend is a Walmart or Grocery store item.Charlie
crazy charlie
