I am in the process of removing the powerhead on my 1979 115 Evinrude for a rebuild. A ring broke due to coking. I am going to rebuild the carbs and replace the thermostats, but was wondering if the block/internals can or should be cleaned...and with what? There is a lot of sticky carbon buildup on the entire backside including the block, pistons, heads etc etc. Since I will be taking everything apart I would like to clean it as well, but am not sure which chemicals if any are safe.
