taylormade
- Apr 1, 2005
- 16
classic fifty red stripe - serial number A744851 (not sure of year- thinking 80's)
-2 stroke /4 cylinder
-manual tilt
-electric start + pull start
picked up boat and motor for cheap....got it running good and not sure of the maintenance of this motor so starting from scratch.....
trying to replace impeller:
ive got all bolts and nuts off with the leg dropped about 3/16 of an inch....but will go no further..
i didnt think i need to disconnect shift rod from under carbs on these models?
i cant disconnect the reverse tilt lock..and i am unsure of what this leg is hung up on....hopefully not siezed to the crank.
what am i missing here? what have i forgotten to disconnect...?
thank you for your help =)
-manual tilt
