I am trying to remove the gear housing so I can replace the water pump. It is stuck and I have not been able to get it off. I used the two nuts on the studs in the front of the housing to push up against the middle section and push the gear housing down (used sheet metal straps to keep from munging up the mid section) but that only got me about 1/2 inch of separation.
I have the shifter in forward position as per the manual.
Seems that there is enough rusty junk between the outside of the pump housing and inside of the gear housing to keep it from coming off. I sprayed it good with WD40 and hope that helps when I try again tomorrow.
Anyone have any tricks to get these things off.
Thanks,
Tim
Thanks,
Tim
