I own a 77 Lund Pike 16 fishing boat. It came with a 81 2 cyl 40 hp merc with a 11" pitch prop. I replaced the motor with a 45 4 cyl with a 12" pitch prop. My problem is that the 40 would knock you out of the boat when you gave it WOT from an idle. The 45 on there now idles smoothly, goes at WOT all day, but seems to "lug" out of the water. Its top speed is 3-4 mph faster than the 40, but I don't think it could pull a skier out.
I just wanted to know if this is normal, and I shouldn't worry about it, just replace the plugs and lower lube like I do annually. Or should I start looking at timing or carb cleaning/adjustments. I did a compression test last fall and they were all 115-120#. I'm just wondering if I should tear into it before the season starts.
Also one colder day last Oct I warmed it up for several minutes, but it only hit on 3 for the first 1/2 mile then took off. Is this linked or just not fully warmed up. Any experience/ suggestions are greatly appreciated.
