I removed my lower unit to install prop shaft seals and new impeller. When I pulled the unit down, The "coupling " that fits on drive shaft splines came with it and dislodged when it caught in the housing as I pulled out the drive shaft. The Question is, how to re-install the "coupling" (or bushing) on to drive shaft and (I assume ) back in to the end of the engine crankshaft? Thanks for any advice . Also, I forgot to put in gear before removing the lower unit gearcase. How will I get everything to line up for the splines?
