I got a 1977 mercury 175 done the link & sync set timing everything for the last 3 years Ive notice it was idling high around 900 to 1000 in N in the water Ive done every thing to fix this the carbs have been resealed check for vacum leaks put 3 diffrent tachs on it set them all to 12 poles or 6 pulse the carbs have no idle adjustments on them the motor runs great but would realy like to get it idling lower if I move the triger as for as it will go the idleing does not lower by ear are tach but if held to long the motor will begen to chuge and die what do you guy think would make it idle like this you think the carb idle jet need to be replaced thanks in advance
