Today when I turned the ignition to crank, nothing happened. I finally realized the ignition switch was not getting voltage. Turned out, there is a 20 amp, push button circuit breaker above the ignition switch that was bad. I by-passed it and everything worked fine. Question....How important is the breaker? I have yet to find a fuse box. So is that the only protection for the ignition circuit?
