Re: Chrysler tool
You're probably not going to find one at a dealer. I've been looking for it myself, with no luck. However, the Seloc manual gives an alternative procedure to accurately time the Chrysler 35-55 engines without the tool. Also, your post would probably get more response in the outboard motor forum. If you have a 6" caliper, you can do it quite accurately. Just take the stroke the engine(2.540")divide by 180. multiply results by your BTDC(28,30 or 32). Take this dimension and subtract it from 2.540". The resulting number is where you have to be to have the points on #1 cylinder just starting to open. All you have to do then is adjust your spark control link accordingly. Make sure you are at WOT when doing this.
