MickLovin
Master Chief Petty Officer
Thread starter- Joined
- Feb 18, 2013
- 822
Hi guys, have had my motor in an esky flushing it and running it off and on for 2 weeks, after showing some people my boat, I went to lift the motor and the tilt motor started slowly then stopped, I checked it out and had to pull it off the reservoir to look into brushes, I found that moisture had gotten in the top and had rusted around a brush which stopped it from being sprung onto the shaft, also causing it to overheat,. I cleaned out the rust and freed up the brush, my problem now is the brown wire has broken off the brush assembly and was originally pressed on not soldered. I tried soldering it but the solder won't hold to the tab nor the cable. Is there way used that this can be re-crimped onto the brush assembly, or am I up for a new motor.
I have had one repaired before by a motor rewind place, but just wanted to see if anyone had fixed this problem before and how they fixed it.
