chrysler guages on a merc
I would like to hook up a tach, speedo, volt meter to my 81 merc 40hp. I found some gauges from a chrysler o/b. I can't find a speedo made for an 81 merc. Is there even a way to hook it up. Sorry for the ignorance.:facepalm: I'm learning as I go.
zorak
Re: chrysler guages on a merc
I am sure some merc experts will chime in on this one but i will telll you what i know. An Outboard's tach signal comes from the stator.I think Chrysler uses a 20 pole stator and mercury uses a 12 pole so it will not work unless there is a selector dial on the back of the tach to allow usage on different engines. One good thing though,if you look on the net you can find a new tach with a fixed 12 pole setting fo 20 bucks . I did and it works great. Speedo isn't outboard dependent. It uses a Pitot tube mounted to the transom to drive the speedo.They are universal so any marine shop will sell them. Volt meter should be universal as well. Good luck.
zorak
Check your private messages.
