Hey folks all the way from New Zealand!!!<br /><br />Got a 90hp Chrysler (big old white thing) that has no spark, I have been told that it has a kill switch and that may be why it isn't firing, anyone know where this kill switch may be??
90 HP chryslers had three different typs of ignigions. You will need to post your model number. It should be located somewhere under the carbs near the cowling latch. Also if you know it which ignition do you have. Either a magnapower CD ignition, magnapower breakerless ignition or a battery ignition with alternator.<br /><br />I dont think chryslers ever came with lanyard switch so the only engine kill switch is coming from the key going to the terminal strip on the motor.
