I have a 74-79 chrysler 75 hp model # 757HC<br />serial # 19440 . Ignition- cd Rapaired 523301-1.<br />I just bought boat $100.00 needs floor and motor wont start but backfires about every 8 turns.Plugs fire outside engine and carbs seem to be working.<br />I tried to set timing but unsure of process.Removed flywheel to check key. Key was ok but broke distributor belt.Ordered belt on line.I need help with setting timimg and how to check out electronic ignition without special equipment.I have multi meter and timing light and motor shop manual.Manual explains how to use test equipment I dont have.Based on experince with car and cycles it seems fire is real weak.Tried coil off 50 hp no help .
- Any help will be great.
