Re: Chrysler 70 HP idles fine, dies at high revs
Nestegg, this is a long shot and may sound stupid. Somebody ran new fuel lines on my 70hp Chrysler before I got it. The first time out I would get into approx. the same range as you and the motor would die. Found out, only when I got home of course that the fuel line was run between the throttle stop and throttle linkage itself. When I went to accelerate, the motor would just cut out. The hose was pinched between the stop and throttle. Mind you, I had no more throttle at this point. Only enough to cut off the fuel supply.<br /><br />Just a thought.<br /><br />Dymo
