chrysler 6hp outboard info needed please
heubach87
Hi i currently have a crysler 6hp outboard, it runs pretty good. fuel leaks from the carb tho and i have no idea where to locate a kit.
the only info i can find on the motor is its a 6hp, model# 62ba, serial# 8209, the carb says tillotson on it and is stamped CO2A.... could any one tell me what that stuff means such as year? and also maybe point me in the direction of parts?
thanks
wickware
Re: chrysler 6hp outboard info needed please
Try Franz's for parts and answers to questions. Please post a pics with the carb showing and full motor (2).
Franz's Marine Service
(816) 966-8085 / 12608 3rd Street, Grandview, MO 64030
________________________________________
New & Used Outboard Parts Shipped Worldwide
Chrysler, Force, West Bend, Sea King (Chrysler Made), SportJet
Factory Chrysler / Force Parts
Factory Authorized Parts and Service
Service: Diagnosis, Repair, Maintenance
Used and Rebuilt Motors For Sale
Try Franz's for parts and questions. Please post a pic of the motor with the carb showing and full motor.
Franz has over 30 years of accumulated parts and experience. He is a factory certified
Force technician and is a member of the Kansas City Marine Dealers Association
and the Marine Retailers Association of America.
Hours: Monday- Friday 10-6 (Central Time)
With Extended Summer Hours!
E-mail us: FranzMarine@aol.com
Franz Buddenberg
(816) 966-8085
heubach87
Franz Buddenberg
(816) 966-8085
im from canada would he happen to have a webpage? and i will post picks when i get home from work... thx tho
wickware
franzmarine.com
The info that you see is basically what you'll see on the web page. I'm curious to see if your carb might apply to other small engines and possibly a small engine repair shop will possibly have your need. It appears that some 4 hp Chryslers were 4 cycles but I doubt that went into 6 hp or even 5 hp (which uses 2cycle mix).
heubach87
franzmarine.com
here are the pics of the motor, and yes it is a 2 cycle
wickware
Take a look in your carb (try to know your specific needs), it might need a simple float adjustment (level inverted), needle, seat, gasket or etc. I c/n clearly see the carb but I w/n hesitate to check a local small engine repair shop or marina for a kit or minor parts if needed.
jerryjerry05
Like wick suggests look in and see what's needed.
Most cases the only thing you need is a good cleaning.
Be carefull if you soak it. Soaks can ruin rubber/plastic.
Valley Sales in Prudenville,Mi. he probably has the parts if you need any.
