dunnbeetle
Thread starter- Joined
- May 29, 2015
- 7
Hi guys,
Just picked up my first boat, a 1970's Crestliner with a 55hp Chrysler engine. I got the boat very cheap, so was expecting issues with the outboard. Long story short, I got it home and checked the compression - One cylinder was at 110 and the other one was at 70. Checked with throttle wide open and both plugs out, multiple times. I then also noticed that the lower unit had been cracked and jb-welded by someone and is still leaking.
I started looking at other outboards and came across a listing on craigslist - "50 horse Chrysler outboard - FREE". The ad describe the motor as one that has sat in the shed for 20 - 30 years. So I was like, well I'll go check it out and maybe I can use it for parts. I get to the guys house and tell him about my situation and that i'm just looking to see if there is anything I can salvage off of the one I'm picking up. The guy replies "well this has 0 hours on it". And I ask if it was rebuilt, he says no and that he just never used it and has been sitting in his shed. The outboard looks fairly clean and the prop has almost no wear.
So I get the motor home and take the cover off, there is some corrosion/rust on some things and I cant turn the flywheel(only tried gently by hand). So right now I have it sitting spark plug side up and I have sprayed some PB Blaster into each cylinder and am going to let it sit a few days.
My question to you guys is, will any of the parts off of my 55hp fit on this 50hp? If this 50 horse has good compression, I plan on going through the water pump/carbs/fuel pump/lower unit fluid. Just wanted to know if there is anything I could use from the 55hp if something is rusted/frozen up. Maybe even the starter?
The 55hp is hooked up to my boat with the controls, the 50hp came with control wires but no control box, am I going to have an issue with that?
50hp - 1983 - serial 507h3d
55hp - I will have to check but I believe it is a 1972 or 1973
I haven't dug into this too much yet and I really know nothing about boat motors, but I have rebuilt car engines in the past. I have done quite a bit of searching and have been able to find parts pretty easily, but there is not a lot of info on the interchangeability of the 2 engines, and really not a lot of info on the 50 horse at all. Any help would be greatly appreciated.
Thanks.
Thanks.
