n8dogg1616
- Aug 5, 2003
- 15
i am having trouble with the top cylinder not firing. the first week i took it out it ran like a striped ape. now it will idle fine and drive with a third of the power but the top end is not there. it will jump at an idle sometimes like it is trying to go into to gear. i took the flywheel off because i was getting a 12volt from the top cylinder coil from time to time but not a constant. amyway the points on the motor are bent alittle bit so the points don't line up perfect. i have bought new points for the engine but have no idea how to set them although i know it needs to be .02 gap. if anyone could help in telling me how to set the points and how the wires inside the flywheel are setup it would be great and if what i am doing is even close to what is wrong with it running on one cylinder. thanks nate
