Chrysler 45 HP outboard 457HA with alternator.
NateFoerg
Hello Gents!
I have been studying the wiring diagram for this engine, but I don't seem to be able to get any solenoid click or starter power. Batt is good. motor/battery/3 terminal ign switch are all outside of boat. I only want to get wiring hooked up enough to test motor.
The previous owner had the motor running, but I cannot seem to figure out how to wire up a 3 position ign switch. I do not have the correct chrysler 6 terminal ign switch.
Any thoughts on how to wire up a 3 terminal ign switch?
I hope you might be able to assist!
Thanks,
Nate in Ann Arbor MI
jerryjerry05
Not absolutely sure but I don't think a 3 post switch is gonna work.
​Without the right switch you run the possibility of burning up the ignition??
