Chrysler 360 Plug Gap
dev2424
I ran the RPM's up on my LM360 and bent an intake push rod. After replacing
the rod, and checking the timing, I tried to fire it up. No go. I checked the other bank
for valve train operation and then checked the plugs. I found #6 #3 #5 plug gaps to
be closed tight to the electrode and angled closed. Regapped and started the engine.
Idled perfect for about 4 seconds then heard "tink...tink the motor stalled out.
Any thoughts? Mechanical...carbon balls??
Tahorover
Re: Chrysler 360 Plug Gap
How is your oil pressure? How many hours on the timing set?
dev2424
Oil pressure is excellent (60 psi warm) New short block 10 tears ago 300 hrs. on motor
1/8 in play on timing chain within tolerance. TDC #1- rotor right on #1 plug wire
Tahorover
Pull all 8 plugs and crank her over. You may find bits of piston.
Gettinther
If you bend a push rod the valve is likely colliding with some foreign matter or piston or any combination thereof, but I have seen valves seizing in the valve guide and cause the same type of problem.
You should remove all the plugs check for debri in the cylinders.
Do compression check. (warm engine if possible)
dev2424
After pulling the plugs and winding it over ,I found no debris.however #4 plug was closed up while #6,3,5 were normal after cranking without starting. I,m hearing water in the fuel acts as a pump ( a possibility) next up compression check THANX FOR YOUR INPUT GUYS
Gettinther
If the plugs are getting hammered shut something is hitting them
Who dropped the washer in there
And pieces of metal will jump from cylinder to cylinder
Never seen water close a spark plug until a piston broke
dev2424
Update: Fuel ok no water. Started it up, Idled fine for 8 secs, then it started, missing sputtered out. No plugs closed up
but after hearing a clink on the right bank just before it died, #3 cylider has oil in it.
Gettinther
I'd be pulling the heads
