Chrysler 35 HP part numbers.
strtbobber
Can anyone help me with part numbers please.
35HP Chrysler
Model # 35742
Serial # 1147
I need part numbers for the following: Water pump, impeller, carb kit, fuel pump kit, thermostat
Thank you!!
eurolarva
Re: Chrysler 35 HP part numbers.
fuel pump kit is 18-7806 carb kit is 18-7037 (Iboats sells both of these. There are a few different impellers that will work but I feel the 6 vane is the best that number is 47-F433065-2. Mercury outboard parts dealer should be able to get you this part. Thermostat is F97068-1 and the thermostat cover gasket isF97067
strtbobber
Thanks a lot euro!! That's very helpful.
Are those Chrysler numbers??
strtbobber
Thanks euro!
Are these actual Chrysler numbers? Just curious how I quote these numbers when I'm calling around.
roscoe
The 18-7806 and 18-7037 are Sierra parts numbers, which are sold here on iboats, and elsewhere.
The other 3 numbers are Mercury numbers, Mercury is the official Chrysler parts supplier since they bought out Chrysler.
strtbobber
Makes sense. Thanks again!!! Much appreciation.
