Chrysler 130 HP 1307HB replacement prop?
YukonDelta
I have a Chrysler 130 HP outboard model 1307HB. I’m trying to figure out where to find a prop that will fit, there’s really not a lot of info about 130 because it was only made one year (1972-73) I believe.
I have it on a 25’ 1976 Yukon delta houseboat and am only getting to around 2k rpm, So I’m trying to find the correct pitch prop to move into the higher rpm at WOT.
I keep reading that Michigan wheel makes Chrysler props, but can’t seem to find anything that states it fits a 130.
I’ve done a ton of work to it, and it was running all summer. However I recently rebuilt the carbs because it had a leak, and now it’s dying out when I give it throttle. Im sure I’ll sort that out, but curious if anyone has ideas.
Thanks.
jerryjerry05
Any Chrysler Force up to 1994 should fit your motor.
What pitch is on the motor now?
This is a guess: 25ft. 130hp needs a 11p or 13p prop??
Finding an 11 might be tough?
There's a bunch of 13's on Ebay
