Can anyone provide detailed procedure (Or a source for this information) for removing the flywheel from a 74 Chrysler 10HP outboard, Model 104HA. This is the unit with the Starter/Generator mounted on top of the crankshsft. I removed the Generator by removing the center bolt. This left a fairly long extension on the crankshaft. I found no retaining nut on the flywheel and flywheel is not drilled or threaded for puller bolts. How does one get the flywheel off? Thanks!
