MickLovin
Master Chief Petty Officer
- Feb 18, 2013
- 822
Hi guys sorry to ask so many questions, but if I don't ask, I don't learn, so you have to put up with me .
Ok I have a kit for my tilt ram and trim ram, I have lifted my motor to 1 inch above bottom of keel as I felt the motor was heavier than my 75hp and because of my 20 gallon tank ( Amercan Talk there ) and batteries, it had a bit of weight towards the end of the boat dragging it down a bit, I have weighted it correct port to star, but it is heavy at the rear or is it stern, any way the motor was coming off the trim ram to the tilt ram to trim the motor properly and I noticed my hydrofoil at least 1 inch below the water. when I tried to trim up on the tilt ram it sucked back down to the trim ram.
Firstly is this correct that it should suck down to the trim ram, do I have a problem with my tilt ram ( no probs lifting the motor when idling or trailering, just when planing). And if I do have a problem with my tilt ram can I take it off without lifting the motor off and chocking the motor so no weight is on the rams? It looks difficult to get to the bottom pipe of the tilt ram, I don't think I need to take off the trim ram as it seems fine, but I do have the kit.
