Re: Choosing a prop
FYI, 200 rpm per inch of pitch is merely a very loose generalization. That will change greatly with different pitches and rpm ranges. Changing the pitch of a prop is like changing the gearing in a car. You are dealing with ratios not set amounts. As stated already, a lower pitch will give you more power out of the hole and a higher pitch, until you run out of power, will give you a higher top speed.
In theory, and not accounting for the horsepower rising with the rpms, 4000 rpm with a 17 pitch equates to 5500 rpm with a 12.36 pitch.
4000/5500x17=12.36
Based on that, I personally would have have tried a 13 pitch just as you did and appearantly you made a good choice. Glad to hear it is working out for you.
Hooked422, if you were happy with the performance of the old prop, I would replace it with one of the same pitch. If it was sluggish, go with a slightly lower pitch and if it was overreving, go with a slightly higher pitch.
