choking
ernie88
I have an older mercy outboard 125hp 6 cyl. When trying to start cold I put choke on and all 3 carbs are covered by choke plastic. It won't start after long cranking, so I put my hand over middle carb and it starts right away, ant ideas would be greatly appreciated so don't have to take cowling off to start it TIA Barry
Chinewalker
Those older Merc chokes are known to get sloppy with age. Usually you can bend/tweak linkages to get full/tighter coverage of the carb openings and make starting easier. Also helps if you prime the heck out of it with the bulb, forcing a bit of fuel by the carb floats in the process. Cold blooded creatures, these beasties are...
Chris1956
Make sure it is cranking fast enough to choke up. Cleaning the battery connections and cables is a good idea.
An OMC primer injector will solve hard to start problems.---Should be lots of good used ones out there.
