Re: Choke solenoid issues on 25 hp johnson
You are an electronics tech and as such you should know there are lots of components that measure 1 ohm. A diode to ground serves no purpose in the choke system because if installed in the forward position it would represent a short to ground when you energized the choke circuit and it would immediately fry the diode. Installed in the reverse direction would make it a "do nothing" element. If you are using an analog meter, set it to x1 and zero it. If using a digital meter it should also be capable of reading 1 ohm. You indicated you rewired the engine side of the system so it is very likely you did something wrong that is allowing +12volts on the coils. It isn't supposed to be there. The engine does not require +12 volts to run since it is a magneto system. This should not be a difficult trouble shoot. We can't see what you did but if you drew a wiring diagram of what you actually have, we could compare it with what you SHOULD have. But then you should be able to do that yourself. I personally feel you have misinterpreted how the two 'M' terminals on the ignition switch are wired. Those have nothing to do with +12 volts. They are simply open circuit with the engine running, and closed to kill the engine. They short the ignition to ground to stop the engine. Concentrate on those two terminals.
