i've got a 30hp '85 Johnson Sea-Horse.
the screw that holds the choke lever broke the other day so i opened the case and put in another screw and cleaned it out. now the choke keeps popping up and jamming the throttle when i move through idle. it seems the little plastic notch on the small plastic piece on the choke side of the case doesn't want to disengage itself from the larger plastic piece on the throttle side of the case.
if i move from forward to reverse, it pushes the choke up when it reaches idle and i have to push the choke down and hold it in order to get into reverse...and vice versa.
any idea what's causing this?
andrew
andrew
