Re: "choke" not working
I dunno, on an 82? Not sure if those had primers or chokes. If it's a choke, there'll be a simple solenoid that should pull the choke flaps over the carb throats, probably on 2 of 3 carbs. In either case, test like IBNFSHN suggested. Only difference would be the wire color I think. Just find the unit and you'll find the wire.<br /><br />If you have the primer, there has to be fuel pressure there to squirt the gas. As you crank the motor, that will slowly build. But if you squeeze the primer bulb until it's firm, that's all it takes. And yup, the primer or enrichener solenoid squirts a dose of gas. I think early primers only shot a fixed amount of gas just that one time. You might have to hit the choke switch repeatedly to get more to squirt.
