chevy to ford swap
Jay Curtis
i have a boat with a 302 ford merc 188 out drive 1986 i think
and a boat with a bad 305 chevy 1989 Merc 205?
how hard would it be to stick the ford in place of the chevy?
thanks
Re: chevy to ford swap
thanks
Ayuh,... Welcome Aboard,...
That Ford is Way older than that, 'n Nope, it won't fit in the other boat either...
Jay Curtis
can i swap out the entire engine and out drive or is the hole in the hull different?
thanks
Howard Sterndrive
hull hole is the same. if you have everything from water pump to propeller, it can be done
about 100 times harder than just finding another 305 or 350
Jay Curtis
i really messed up the boat with the Chevy is a 1979 so about the same vintage as the ford boat
does that make any difference
mkast
Take the GM power package out.
Install the Ford package.
If you don't tell the hull about it, I won't.
