Volvo-chevy 350,replaced plugs,wires,points,condensor,cap,and rotor. Have rechecked firing order,dwell at idle is right at 30 degrees,and timing is right on. I also winterized a 120 gallon tank with only a 1/4 tank,and i must say,i cant remember if i added any stabilizer! Engine starts better than ever,idles perfect,everything fine up to about 2500 rpms,then breaks up,seems to pop through carb,and i cant get any more rpms out of it.I replaced fuel/water seperator,and no differance.Think its bad gas??<br />Thank You all.
