Re: checking OMC outdrive gear lube
Ok, here IS the reason you must/should fill the drive from the middle. A Cobra drive uses a outboard gearcase housing.SAves money by utilizing one gearcase vs. making two. Just aft of the shift shaft cavity, there is a protrusion inside that effectivly creates an air pocket and traps air. On an outboard this is not a problem but on the Cobra, the oil must travel up to fill the upper gearcase to the proper level. The oil will go up into the upper if filled from the bottom but the pocket of air remains. By filling from the middle hole, oil goes down into the forward pocket and back up and eliminates the air pocket. What will happen if not done correctly is that the air pocket WILL migrate soon after running and now the upper gear oil level is too low. The small rear horizontal shaft bearing in the upper will burn up!!!!!! <br />IF, and this may get confusing, IF, you fill the drive fromm the bottm AND leave the middle plug out untill oil comes out of the middle, you could fill from the bottom.That way you would allow the air to escape From that shift shaft cavity. BUT only if you do it that way. So really, everyone is instructed to do the middle thing and avoid confusion. When ever someone comes in with outdrive problems I always ask if they filled the drive correctly, From the bottom, right?? Of,course, they say. Now I now if they screwed it up themselves.
