Checking Engine Alignment - replace gaskets?
eavega
Hello All
so, as temps get cooler, thoughts start to turn towards the inevitable winterizing of my 3.0L Mercruiser/Alpha 1. I'll take that time to verify the engine alignment, but was wondering if every time you remove the outdrive (to check alignment, check/change impeller, etc) does it require you to change out the gaskets and o-rings? If I am not mistaken there is one big gasket and two rings.
I have every intention of changing the gaskets out when I winterized, but was wondering if I have to plan for it every time I would need to remove the outdrive.
Thanks in advance for your replies.
Rgds
Eric
Re: Checking Engine Alignment - replace gaskets?
Ayuh,.... Whenever the drive is pulled ya need the gasket set, I use 18-2619-1 for all of the Alpha series of drives,...
It's for the Gen.IIs, but seals All of 'em,....
'bout $6.bucks,...
tpenfield
2 small o-rings and 1 funny looking o-ring type of gasket ???
I get about 5 years out of a set. If you do not know how old they are, then it would be a good idea to start with a new set.
